02 Sensor removal- top broken off
Discussion in '4th Gen 4Runners (2003-2009)' started by Digologist, Nov 14, 2023.
  1. Nov 14, 2023 at 1:15 PM
    Digologist
    Digologist [OP] New Member
    2001 4runner Limited 3.4 liter 4WD
    Okay, I bought a 2005 4runner. Had some problems when I bought it but did not know the extent! Almost 1k in exhaust repair. New windshield.
    After the Exhaust work, they discovered the 02 sensor is missing on passenger side upstream.
    I bought a new 02 sensor and went to install it only to find out the last one was broken off leaving the wire hanging and the screw in part of the sensor still in the port. Tried and failed to remove it using a 22MM socket. Any suggestions on how to remove this so I don't have to buy another catalytic converter just to have a 02 sensor port. Thanks, John
  2. Nov 14, 2023 at 2:27 PM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    With a warm exhaust, spray PBBlaster on what's left of the sensor and let it sit overnight. Then get it hot again and try removing it while it's hot, just be careful not to burn the crap outta yourself :p Might have to do that a few times. Also be sure to use an O2 sensor socket and not just a wrench, unless you use the closed end.
    Digologist[OP] likes this.
  3. Nov 16, 2023 at 4:26 PM
    Digologist
  4. Nov 16, 2023 at 4:27 PM
    Digologist
    Thanks for the info. I will try with a good soaking of PB blaster. I was thinking a long breaker bar to help. Thanks.
