02 RWD drive shaft question.
Discussion in '3rd Gen 4Runners (1996-2002)' started by Hank69, Jan 27, 2024.
  1. Jan 27, 2024 at 9:27 PM
    Hank69
    Hank69 [OP] New Member
    Hank
    2002 Blurple 4runner
    Hey all.
    When I bought my 4Runner I was told that they had fabricated a new drive shaft because the one in it had been warped a bit.
    (Done at a shop, not a home job)
    I believe the rear U-joint is the source of a clicking noise that I've been having.
    It doesn't twist back and forth like it's loose, butI can slide the bearings in and out about a 32nd of an inch both directions.
    My issue is it looks different in the rear than the drive shafts I see in the manuals and on instructional videos.
    The images and videos I see show a ""double cardan"" at the rear.
    Mine does not have this.
    Single U-joint at both ends.
    Is this going to be a big deal in the long run?
    Should I just find myself a stock drive shaft and replace the whole thing?
    Anyway, I appreciate all of you and all the help.
  2. Jan 28, 2024 at 2:57 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    The double cardan is in the 4WD version only. If you have a 2WD 4Runner, you won't have one. If you have a 4WD version, whoever made the driveshaft screwed it up.
    If your rear U joint is sliding back and forth that way, it's going bad. Replace it right away!
    Does that help at all?
    Pat
  3. Jan 28, 2024 at 3:18 PM
    Hank69
    Hank
    Well, it is a two-wheel drive, so thank you very much for that!!!!!
    I guess all the sources I was looking at where four four wheel drive.
    I appreciate the feedback. And... You !
    Thank you Pat !!!
