'02 Ignition clicks, then car dies?
Discussion in '3rd Gen 4Runners (1996-2002)' started by Odjur, Aug 26, 2021.
  1. Aug 26, 2021 at 4:36 PM
    Odjur
    Odjur [OP] New Member
    2002 4Runner
    I've owned the vehicle for a month and a half and never had any electric related issues or issues with starting. Got to my car today and turned the ignition, everything lights up like it should, then when I turn the key to start the engine, there's a click and everything dies. Everything electronic is not working.
    Any suggestions on where to begin? I would assume the battery is bad, but it happened so suddenly with no warning... has this ever happened to anyone here?
  2. Aug 27, 2021 at 8:32 AM
    mem4runner
    mem4runner New Member
    Tim
    NOLA
    1997 Base 4cyl. 5spd, 2019 TRD OR
    Definitely start with the battery and then go from there
  3. Aug 27, 2021 at 12:51 PM
    Odjur
    2002 4Runner
    The battery reads 4.8 volts, I suspected it’s bad since I found a spare one in the trunk (assuming previous owner was about to swap it). The spare one reads 11.85 but there’s a sticker on it that says 7/17 — I’m assuming it’s the expiration date?
    Should I try to charge the spare battery or just go ahead and buy a new one?
  4. Aug 27, 2021 at 2:32 PM
    Try to use the old one. No harm in it.
    That sticker is the build date.
  5. Aug 27, 2021 at 8:21 PM
    Odjur
    2002 4Runner
    Thanks,
    I went ahead and put in a brand new battery just so I know I won't have any issues in the future, and since I needed to move the car fast.
    When I just put it in it read above 14 volts. Then I drove around for a bit and noticed it dropping lower and lower, before parking it at home it read 13.45 while engine is running. Isn't that way too low for a brand new battery? Should I assume the alternator is bad? Or could this happen with bad battery connections? The red cable looked pretty corroded...
  6. Aug 28, 2021 at 7:08 AM
    Either could be a problem. What voltage does the battery say while running?
    Your battery should have been 12v new. I would suspect a battery that reports much over 12v just sitting out. Are you testing with the car running or not running?
    Battery can be like 11.8v with car off or a bit higher. With car running, you should see 13.5 v or more.
    An alternator will put out from 13.5v to about 14v.
    So your current battery voltage is as high as normal alternator output.
