00' injector problems
Discussion in '3rd Gen 4Runners (1996-2002)' started by kirbyschroeder, Feb 21, 2020.
  1. Feb 21, 2020 at 6:08 AM
    kirbyschroeder
    kirbyschroeder [OP] New Member
    Hey I have a 2000 4runner that I just replaced the injectors on. With the new injectors the car is struggling to start a little bit more. Although when its cold, like 20 degrees outside it starts perfectly normal like it had before I replaced the injectors. It also is misfiring at idle but runs perfectly fine under power. Any tips or ideas?
    captsolo likes this.
  2. Feb 21, 2020 at 7:38 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    Put the old injectors back in and note any performance issues in the cylinders.
    I have 150,00 miles on my 2005 V6 and she has original injectors, and starts and runs like when it was new.
  3. Feb 21, 2020 at 8:44 AM
    kirbyschroeder
    I would but the reason I changed them was because one of them was leaking. I also have 330,000 miles on my vehicle so I think it was probably a good idea to change them anyways.
  4. Feb 21, 2020 at 8:55 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    Scott Kilmer would say just drive it. Sounds like a minor issue.
  5. Feb 21, 2020 at 10:06 AM
    Did you buy Toyota injectors? If you got them off from Ebay or Amazon...they are JUNK. All are FAKES.
    I would only buy Toyota injectors OR get them from a Toyota performance site that flow tests and matches injectors.
    How was the old one leaking? Around the o-ring? Just get new TOYOTA o-rings (they are different than part store #6s).
