0 Offset wheels and 265 tires will rub?
Discussion in 'Wheels & Tires' started by mgm4runner, Jul 30, 2023.
  1. Jul 30, 2023 at 10:56 AM
    mgm4runner
    mgm4runner [OP] New Member
    2023 SR5 4Runner
    I just got my 2023 sr5 4runner and Im planning to upgrade wheels and tires. Im getting a good deal with wheels + tires. From what i have read online, stock wheels have a +12mm offset, would there be any rubbing if i go to a 0 offset wheel and some 265/70r17 tires?
  2. Aug 3, 2023 at 12:11 PM
    rhexis
    rhexis New Member
    i have 0 offset wheels and 265 tires and i did have a slight rub on both sides on the mudflaps. once i removed those i was good.
    mgm4runner[OP] likes this.
  3. Aug 3, 2023 at 12:20 PM
    J0hnny
    J0hnny New Member
    0 offset wheels with 265 70 17 KO2s and no rub
    mgm4runner[OP] and satoshi like this.
  4. Aug 3, 2023 at 12:49 PM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    What wheel width? This will play a factor in the equation as well.
    I went with 8.5" wide x 0 offset wheels. Stock size Falken Wildpeaks AT3 C load rating. Very minimal rub on front left mudflap and very rarely. It only happens at full lock on an incline. Not enough for me to do any mods so everything surrounding the wheel is still in stock form.
    I have a 1" front level only spacer though.
    2015 SR5P.
  5. Aug 4, 2023 at 6:00 AM
    mgm4runner
    2023 SR5 4Runner
    Thanks for the replies, I went all in an got 8.5 wheels with 0 offset and some 265/70 tires and I got no rub! It is super close to the front mudflap when in full lock but no rubb. I ll probably need to do the fender liner mod when airing down tires when offroading tho
    raimieb and TrailSpecial22 like this.
  6. Aug 4, 2023 at 6:02 AM
    mgm4runner
    2023 SR5 4Runner
    Interesting, I havent tried full lock on a incline, I will def give it a try
  7. Aug 4, 2023 at 2:31 PM
    Nchaps21
    Nchaps21 New Member
    2016 Toyota 4runner
    Are those the The E Load Baja boss or the SL?
  8. Aug 4, 2023 at 2:51 PM
    mgm4runner
    2023 SR5 4Runner
    yes, the E Load Baja Boss AT
  9. Aug 22, 2023 at 11:05 AM
    MontanaMarine
    MontanaMarine New Member
    Dave
    2023 Off Road Prem 4runner
    All-
    Instead of starting a new thread, I'd like to piggy back here.
    I've got a 2023 Off road premium, and also want to get new wheels and tires. I live in the mountains and it's all off road, especially during hunting season. The all seasons it came with will not cut it here.
    I want a wider stance, and was looking to go to 0 offset as well. NO spacers for me. I don't plan to go bigger with the tire, 265 is fine, just need all terrains. I have zero mods, and don't plan on any. Just wheels and tires, with a wider stance gained via offset.
    My question:
    How far of an negative offset can I go before rubbing? It is my understanding my OEM wheels are 17x7.5" with +15mm offset. I can only find 8.5" wide rims.
    *I have used the search function extensively, and seen a bunch of info, and even arguing, but no answer to my question.
    Thanks Gents
  10. Aug 22, 2023 at 11:17 AM
    Treetopflyer
    Treetopflyer New Member
    2018 TRD off road
    Not sure on actual limits but if it helps I’m running currently TRD pro wheels (+5 offset I believe?) with 275/70/17 and only had a tiny tiny rub on the mud flap.
    MontanaMarine[QUOTED] likes this.
  11. Aug 22, 2023 at 11:22 AM
    MontanaMarine
    Dave
    Thanks for the reply. Would you mind sharing a from front front looking down the side so I can see the stance? The dealer (of course) recommended I go with the pro wheels, and I'm not sure if 11mm is substantial enough to "offset" the cost...haha
    Captain Spalding likes this.
  12. Aug 22, 2023 at 3:09 PM
    Treetopflyer
    2018 TRD off road
    hopefully you can see ok…
    MontanaMarine and Thatbassguy like this.
  13. Aug 22, 2023 at 3:37 PM
    MontanaMarine
    Dave
    Perfect-thanks
  14. Aug 22, 2023 at 6:42 PM
    satoshi
    satoshi Mοderatοr
    2023 TRD ORP LUNAR ROCK
    23 ORP. 0 offset 17x8.5mm KMC Dirty Harry wheels with 265/70R17 Toyo OC AT3. Stock suspension no rubbing!
    ORP stock wheels are +15mm offset
    RushB, MontanaMarine and Thatbassguy like this.
  15. Aug 22, 2023 at 6:52 PM
    I had rubbing with -6 offset and stock size KO2's. But, it probably could have been solved with a fender liner mod and/or some minor trimming.
  16. Aug 22, 2023 at 8:25 PM
    MontanaMarine
    Dave
    All-thank you
    I’ve got it narrowed down to either 0 or maybe -6
    Dont see many options for -6 wheels. Any suggestions? Best place to purchase/look?
    Thanks in advance!
  17. Nov 8, 2023 at 1:08 PM
    mr h
    mr h New Member
    scott
    Tucson, AZ
    front leveling kit, dog fur
    just adding on here…
    my 2018 with 5100’s on the .85” setting still rub on full wheel lock in reverse with 17x 8’s and zero offset with 265 wilderness peak’s
    hoping ko2’s fix that someday. those falkens seem to have a really wide tread foot print.
  18. Jan 14, 2024 at 7:25 AM
    kurtis2244
    kurtis2244 New Member
    Kurt
    2014 4runner SR5
    3 inch lift
    I'm new here and trying to find a thread on offset. I ordered wheels and tires. They came with a 0mm offset and won't even go on. The caliper hits and they won't go on. The company I ordered them from have no idea why. Can someone please help on why they won't go on. I sent them back.
  19. Jan 14, 2024 at 7:48 AM
    You probably have a backspacing issue on the new wheels.
    Stock wheel backspacing is 4.5".
  20. Jan 14, 2024 at 9:18 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
    Where do you measure the "4.5" inches from?
  21. Jan 14, 2024 at 10:18 AM
    The wheels you purchased should give you the backspacing specs but here's an illustration to show how to measure.
  22. Jan 14, 2024 at 1:24 PM
    mr h
    mr h New Member
    scott
    Tucson, AZ
    seems like they got the wrong wheel for a 4r or your year
    no way a zero offset does that, or any offset for that matter.
    you go to some shady tire place with smooth brain employees?
    i ended up with new toyo open country r/t trails and no more fender rub
    Trees91 likes this.
  23. Jan 15, 2024 at 1:24 PM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    Method 705's? My current debate is those or the FN wheels Overlander Spec A (which are -6mm) But I want to go 275's (probably Toyo AT3's) and have to stay under the fenders (stupid laws here).
  24. Jan 15, 2024 at 1:31 PM
    mr h
    mr h New Member
    scott
    Tucson, AZ
    correct 705’s 17x8.5” with zero offset
    -6 will have a little poke. my previous 4r had some negative offset and they hung out a bit more
    the previous owner had to remove all the inner fender plastic to keep the rub away. i wasnt about to take that route with this one. i really dislike hosing all the mud off the body and suspension.
  25. Jan 15, 2024 at 2:18 PM
    Chillmatic
    Chillmatic New Member
    My winter set up is 17x8.5 ET 0 with 265 blizzaks and I have zero rubbing at all.
  26. Jan 16, 2024 at 12:42 PM
    mainerunr
    Maine
    '23 TRD ORP
    Thanks. Guessing I go with 705's before these tires are worn so I can see if I think I can get 275's without poke since it sounds like the combination of the Fn Wheels and 275's would poke more than I can get away with here.
  27. Mar 20, 2024 at 9:02 AM
    cjmdwyer
    cjmdwyer New Member
    I am looking at some TRD pro replicas and they are 17 X 9 with zero offset. Will the wider wheel make rubbing more of an issue? Considering painting my TRD ORP wheels and 1.25 spacers instead.
  28. Mar 20, 2024 at 9:10 AM
    mr h
    mr h New Member
    scott
    Tucson, AZ
    you’ll get rub, depending on tire.
    my wildpeaks 265’s rubbed but the new toyo’s dont and that was with the bilstiens up at .85”
