“Leaking” noise when water runs down windshield?
Discussion in '5th Gen 4Runners (2010-2024)' started by nodents2017, Jan 8, 2024.
  1. Jan 8, 2024 at 12:21 PM
    nodents2017
    nodents2017 [OP] New Member
    I have a 2022 TRD Off-road without sunroof with about 16k miles and noticed recently that whenever there’s water in the roof and I hit the brakes causing the water to roll down the windshield, I get this hissing/leaking sound as if pressurized water is leaking past a rubber seal. Kind of hard to explain but it almost sounds like when you have a puncture in a tire and you spray soapy water on it to see where the air bubbles are coming from. Anyone have this happen before or know what could be causing it? My immediate concern was if water could be leaking into the cab but I checked the headliner and floorboards and can’t find any moisture or condensation on the windshield.
  2. Jan 8, 2024 at 12:46 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Are you positive it only makes the noise when there is water on the roof?
  3. Jan 8, 2024 at 12:49 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    @3JOH22A
    3JOH22A likes this.
  4. Jan 8, 2024 at 1:32 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    If you have the moon roof it's likely the drains and is normal.
  5. Jan 8, 2024 at 1:33 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    @Rob41
    3JOH22A likes this.
  6. Jan 8, 2024 at 1:36 PM
  7. Jan 8, 2024 at 1:41 PM
    Oakboro, N.C
    Being that you said you do not have a sunroof, Can you narrow it down to one side or another possibly around the cowl area?
    Did you purchase this new or preowned?
    catbrown357 likes this.
  8. Jan 8, 2024 at 1:43 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    :yes:
  9. Jan 8, 2024 at 1:57 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    I'd like "Brake Booster Pump" for $1000 please Alex.
    Swamprat16 and 2Toys like this.
  10. Jan 8, 2024 at 2:01 PM
    3JOH22A Toyota Gigolo
    One way to verify is to power on the electrical system without starting the engine, then press the brake pedal a few times. If that's the sound you hear, then it's normal.
    2Toys and catbrown357[QUOTED] like this.
  11. Jan 8, 2024 at 2:31 PM
    nodents2017
    It seems like it’s coming from the top of the windshield directly in the middle where the map lights are. I’ll try to pay closer attention next time I have a chance to recreate the noise.
    It’s a 2022 that I bought new, currently has 16k on the odometer. Only recently started to notice this noise.
  12. Jan 9, 2024 at 4:05 AM
    nodents2017
  13. Jan 9, 2024 at 5:12 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Do the windshield leak test. Pour soapy water on the outside molding and then from the inside blow compressed air. If it forms bubbles outside, it's leaking from that spot
  14. Jan 9, 2024 at 9:45 AM
    This is the almost continuous sound prominent at the 00:10 mark? I had to put headphones on to hear it. Sounds like either a rubber bushing squeak or a servo motor (like a HVAC blend door that's continuously cycling).
  15. Jan 9, 2024 at 10:35 AM
    nodents2017
    Yes that’s correct, sounds like a squeak. The HVAC was off so I know it’s not that but it does sound like a high frequency noise from a servo motor.
    Such a strange noise and I can’t seem to figure out what’s causing it. I’ve inspected the headliner all around the windshield and don’t see signs of moisture and there no condensation on the windshield after it rains
